Sail Panel - Blistering - GM Bulletin
Aaron Thornton
Admin
Doug Cook It's a well documented issue GM had from 1999-2002 with the adhesive they used eating through the unprimed back of the panel. Complete replacement is the only lasting fix.
George Horrigan
Doug Cook it’s because of glue seeping through the paint due to a lack of primer. Sun and heat often makes it worse
Sail Panel.jpg (132.58 KiB) Viewed 12184 times
Re: Sail Panel - Blistering - GM Bulletin
Sail Panel1.jpg (98.06 KiB) Viewed 12183 times
John Smith Jr.
Make sure your tops are in when you put it on
